Ground ignition connecter ?
hey guys, another dumb question, I think. I want to set the timming after haveing the dist. out of a 93 eclipse 1.8 . The book i have says 2 put a ground jumper from ignition test connecter to a good ground, this plug on my car has 2 tits inside that thing. Do I ground both tits or one of them ?:confused: Thanks fore any help :D Sam
It should only have one wire and that goes to ground.
Thanks dsm1990gsx, I went back and looked closer at that timming wire & it does have 2 tits in it.on closer inspection I notice the 2 tits are made of rubber or are little covers on them, the only single wire is black & goes 2 a condencer 2 ground. Am I looking in the wrong place ? over by the battery.
It should be over by the battery, but theres gonna be two similar connector one for ign timing adjustment and the other is a fuel pump test connector. The one you want has a yellow wire w/ a red tracer.
Originally Posted by dsm1990gsx
(Post 253013)
dsm1990, I found that wire and all went well, thanks 2 you much you saved me alot of time and also you taught me a thing or 2 that i will always be able to use in the future , so thanks again. sam
Originally Posted by pepper
(Post 253256)
(Post 253266)
No problem.
That sucks, well at least the head gaskets are easy to replace on the 1.8.
very true, but dang it sure is cold outside, but i bet there wont be any bad hoses on it after this. I suppose it was supper good luck that the head was not warped or cracked because it got all 4 clinders on the gasket, strange, it had 2 be relly hot but i started it up and it ran fine , so i put water in it and it blowed it back out but it never did miss a lick. now she wants me to change it over 2 auto trany. can this be done with this bisy? like we use 2 do the old cars back in the day?
