Help 92 gs 2.0 problems
Hey guys i have a problem.My sister bought a 92 gs and before we got it back to my house
the clutch stopped working.I guess whoever owned it looks like they had nitrous on it because there is a steel braided hose that goes from the engine to the trunk. There are bolts all over the place that were shaken loose all over,Like from down by the slave cylinder mostly and through out the exhaust.The person she bought it from said it has a new clutch and showed her the reciept.what do you guys think needs to be done???? Just looking to hurry and fix it for her and i dont know much about the 1g 4g63nt any help would be appreciated... |
well i would be very worried if a NT car like that was running nitrous.
But you need to be a bit more specific than "the clutch stopped working". As is do you not have any pedal pressure. Or do you feel the clutch with the pedal but it wont shift. |
Well it doesn't feel like there is any pressure really on the clutch.
and when you go to put it in any gear it just grinds and bounces out. I have never worked on a clutch before so i guess now is as good a time as any to learn about it and get it fixed.I guess i will try and bleed it tomorrow and do you know where the clutch and slave cylinder are located?? |
There is a bleeder on the slave cylinder. Thats located on the front side of the trans, same side as the exhaust.
