Help Me DSM GURU's!!!
Hi there,
Thanks for reading my post. Well here is my problem I'm running rich.I bought a 92 Eagle talon TSI knowing that the only problem is a fuel pump. took it home from a 2 hrs night drive car runs fine on high gears, but from first the car dies on me.once i got home i checked the spark plugs, the plugs are black.Woke up the next morningideled the car to its normal temp the carsmokes white and black. MAANN! first tihing i checked was the fuel regulator the vaccum was leaking gasfrom the regulator. changed the reglator and the fuel pump. still has smoke. after further checking i saw that the screw that connects the manifold to the heads isleaking oil. thats the screw in the middle, finally fixed it no more oil leak butstill black smoke comes out. what should I do? Please Help meeeee.... thanks!! |
RE: Help Me DSM GURU's!!!
Are you running on the stock fuel pump? Any mods?
Yes, Now its running a stock fuel pump, i tried to put in the MAF sensor of my 90 tsi, it worked a little, but still has black smoke. I dont have a cat, on the 92 but i know it shouldnt blow black smoke. coz i used the same set up before.
By the way no mods.
How old is the o2 sensor? You're running rich for some reason. It can be because the ECU can't see an accurate representation of air coming in or it can't see an accurate rep of exhaust content coming out; fuel output is higher than normal, or something along those lines. Speaking of lines, is the EGR system still working and connected? Is the BOV recirc'd or is it vented?
You said the replacement MAF worked a little. Check for boost leaks, change PCV; hell, just do a tune up and go from there. |
Also check the coolant temp sensor b/c when they go bad it'll make the car run pig rich.
ORIGINAL: dsm1990gsx Also check the coolant temp sensor b/c when they go bad it'll make the car run pig rich. |
