-   1st Generation (https://mitsubishiforum.com/forum/1st-generation-62/)
-   -   idling problem on a 1g (https://mitsubishiforum.com/forum/1st-generation-62/idling-problem-1g-7338/)
Reddragon06 Dec 23, 2005 02:25 AM
my 91 gs has an idling problem it jumps up and down from 2 to 1500 rpms. and ive replaced it with 3 different sensors so what else could make it do this.
1997gsteclipse Dec 23, 2005 02:29 AM
RE: idling problem on a 1g
check for vacuum leaks that would be a real good start to finding the problem. Maybe even plugs and wires.
Reddragon06 Dec 23, 2005 02:41 AM
vacuum test on what, i was going to change the spark plugs but ran out of money... lol
Joel_CA Dec 23, 2005 03:05 AM
It could just be that your adjustments are off or that you are adjusting it incorrectly. Remember, there's a CTP switch that needs to be adjusted BEFORE adjusting the TPS. From there you can adjust your idle base settings.
Joel, CA
1990GSX Dec 23, 2005 09:52 AM
also check your altanator belt, mine slips when it's loose and runs bad.
georgegsx Dec 23, 2005 12:22 PM
do u have an aftermarket bov?
georgegsx Dec 23, 2005 12:24 PM
my bad ist a gs nevermind
Sanguinius Dec 23, 2005 01:04 PM
Does it run rough or does it sound like it's hunting? (Like someone is revving the engine up and down)
DSMTalonAWD51 Dec 23, 2005 01:10 PM
you have idle surge. tell us what youve tried to replace to far. Possibilities are a bad isc motor, idle adjustment is off, bad egr, dirty tb, missing/bad vacuume line. no matter what it is, it will be located around the tb
Sanguinius Dec 23, 2005 01:30 PM
ISC? I'm guessing you mean IAC motor? That was what I was thinking it is...
