log
RE: log
ORIGINAL: 92_laser
I will check the plugs tonight when I get off work. As for the boost leak wouldnt my gauge spike if I had a leak?
RE: log
This is my 3rd gear pull.... the only difference is I turned the boost down to 11 instead of 15
RPM KNCK O2-R TIMA
2000 0 .7v 23
2100 0 .13v 21
2218 2 .78v 21
2312 1 .87v 18
2406 1 .89v 18
2500 0 .87v 19
2656 0 .89v 18
2718 6 .89v 13
2812 6 .89v 12
2906 5 .89v 12
3000 5 .89v 11
3156 4 .89v 12
3312 4 .89v 15
3437 3 .91v 16
3562 8 .91v 15
3687 9 .91v 14
3812 8 .91v 14
3906 7 .91v 15
4031 7 .91v 14
4125 6 .91v 15
4218 6 .91v 17
4406 6 .91v 16
4593 5 .91v 16
4687 4 .91v 17
4781 4 .91v 17
4875 4 .91v 19
4937 3 .91v 19
5187 3 .91v 19
5218 2 .91v 18
5375 1 .91v 20
5406 1 .91v 21
5513 0 .91v 23
5718 0 .91v 23
5781 0 .91v 24
It looks to me that I am running lean all the way accross the board... what do you guys think/input???
Thanks in advance
RPM KNCK O2-R TIMA
2000 0 .7v 23
2100 0 .13v 21
2218 2 .78v 21
2312 1 .87v 18
2406 1 .89v 18
2500 0 .87v 19
2656 0 .89v 18
2718 6 .89v 13
2812 6 .89v 12
2906 5 .89v 12
3000 5 .89v 11
3156 4 .89v 12
3312 4 .89v 15
3437 3 .91v 16
3562 8 .91v 15
3687 9 .91v 14
3812 8 .91v 14
3906 7 .91v 15
4031 7 .91v 14
4125 6 .91v 15
4218 6 .91v 17
4406 6 .91v 16
4593 5 .91v 16
4687 4 .91v 17
4781 4 .91v 17
4875 4 .91v 19
4937 3 .91v 19
5187 3 .91v 19
5218 2 .91v 18
5375 1 .91v 20
5406 1 .91v 21
5513 0 .91v 23
5718 0 .91v 23
5781 0 .91v 24
Thanks in advance
RE: log
does your car feel slower than it shoudl be to you? my vote is for boost leak. the stock ecu is designed to max out at 16 degrees of timing by redline. the only way to get 24 is if it sees less air coming in, and that could happen because of using an SAFC to trick it, or having a leak. check all your intake/ic hoses carefully, make sure they are connected tight and if you have any rubber ones, that there arent any tears in them
RE: log
I checked all the charge pipes last night and found no leaks.... other then my bov but that always leaks doesnt it?! Is there anything else that could leak? I might pull my intercooler out tomorrow and check it
RE: log
ORIGINAL: 92_laser
