MORE HORSE POWER
I HAVE A 1992 ECLIPSE 2.0 DOHC NON TURBO 5 SPEEDIS THERE ANY THING I CAN DO TO GIVE IT MORE HORSE POWER LIKE MOVING A SENSOR OR REMOVING THE HONEYCOME IN THE AIR BOX SOMETHING LIKE THAT ANY IDEAS
RE: MORE HORSE POWER
First off no need for the caps lock, there isnt really a lotyou can do for more horse power. You can get a set of 93-94 turbo cams, pull out the balance shafts and hack the air box and get a k&n filter. That is probably the cheapest/easiest way to get more horse power.
right off if you look under your intake theres this black box that is stupid who knows what it does but restrict air..a few screws and you can feel an improvement and its FREE
umm you can clean out your throttle body but dont do what i did and spray ANY SENSOR with throttle body cleaner..use sensor cleaner |
yup, the old cut the box, take a wizzer and cut a big ol' square in that air can, and the k&n filter makes a difference... they are like 50 bucks tho... in these cars, there is realy no need for a new intake pipe, the plastic one in there is smoothe on the inside and is better insulated that an aftermarket metal one, and a big gain is made if u get a maf translator and a GM maf unit, there is virtualy no restriction with those, it will cost around 150 to 200 tho.... lets see, theres realy not alot of options, if you dont want to work on the motor... uve only got two options, intake and exhaust... im in the same boat as u, it sucks i know... i plan on an engine rebuild and the head machined out for bigger valves and larger cams... itle be around 2 grand for all that i think, i can do the rebuild myself but the heads can get expensive
ORIGINAL: laserdriver90 yup, the old cut the box, take a wizzer and cut a big ol' square in that air can, and the k&n filter makes a difference... they are like 50 bucks tho... in these cars, there is realy no need for a new intake pipe, the plastic one in there is smoothe on the inside and is better insulated that an aftermarket metal one, and a big gain is made if u get a maf translator and a GM maf unit, there is virtualy no restriction with those, it will cost around 150 to 200 tho.... lets see, theres realy not alot of options, if you dont want to work on the motor... uve only got two options, intake and exhaust... im in the same boat as u, it sucks i know... i plan on an engine rebuild and the head machined out for bigger valves and larger cams... itle be around 2 grand for all that i think, i can do the rebuild myself but the heads can get expensive |
You could spend about 2000 bucks on a 5.0 mustang and double your horsepower.
ORIGINAL: Michael Knight You could spend about 2000 bucks on a 5.0 mustang and double your horsepower. |
I would assume so the car would be a tad quick
yea man the problem is ur non-turbo car was never made to handle high horsepower... so anything you do really is just make small improvements
ORIGINAL: ByPopularDemand I would assume so the car would be a tad quick |
