Need help please!! Tried everwhere else....
Hello to all :)...I am new to this forum...I have tried everywhere else and hoping i can find help from someone here :confused:...I have a 92 Eclipse 2WD 2.0l non turbo. I accidently ripped off the eco/power button from the console and it is broken. Unfortunately Mistsubishi or Chrysler does not make this part anymore :mad: and I am stuck with a vehicle that will not run properly :(...
Can anyone please point me as to where I can find a replacement...I am the NYC region...I have tried some salvage yards without luck... The part number is MB522935... Thank You to all....:) |
I cant beleive that you wouldnt be able to find one at a junk yard. Those cars are so common to find.
Has the car only run properly until you broke this? |
Yes, car ran smooth....now it is stuck in third gear....
ok so the car went into limp mode because of the TCU. Have you tried resetting the car by unplugging the battery and letting it sit for a couple minutes.
But here is the best place to try and get used parts like this from http://www.mitsubishigraveyard.com/ |
Went down cause of the eco/power switch....gears wont change without the switch connected..:(
