no reverse
i just put in a new clutch in my 93 gs
now i dont have reverse what could it be? |
RE: no reverse
your linkages probably need adjusted
RE: no reverse
when we hooked the linkage up we followed the instructions in a haynes manual
when watching the linkage when my friend trys to put it into reverse it looks like where the linkage hooks up to the transmission it not lifting enough to let it go into gear could it be something in the trans or...? |
RE: no reverse
Can you manually shift the trans into reverse w/ the levers on the trans itself?
RE: no reverse
no we arent able to put it in with the levers on the trans
it feels like something is in the way |
RE: no reverse
Is the clutch disengaging?
RE: no reverse
yes it disengages
RE: no reverse
have you moved the car at all yet since you put the clutch in?
RE: no reverse
yes ive been driving it alot
RE: no reverse
Did you have any problems w/ reverse before? Seems weird you have all the foreward gears but no reverse?
