oil filter bracket
When doing the 7 bolt to 6 bolt conversion the oil filter bracket or pipe does not have the oil pressure guage sending unit on it or a spot to mount one. All it has is the idiot light sender.
Questions; Does any one make a conversion kit as the 7 bolt oil filter bracket (pipe) will not fit on the 6 bolt? Can you use a turbo version with the oil cooler blocked off? If you use the stock 6 bolt without the pressure sensor will the computer allow the engine to run? Where does an aftermarket oil pressure gauge mount it's sensor? Thanks!!!!!! |
RE: oil filter bracket
2 Attachment(s)
the dark one is off a 7 bolt and the light is from a 6 there very diffent. the 7 bolt has a pessure sender the six doesnt...also they mount way diffent...
please *help* |
