please help (newbie)
hey. first off, im new. i have a 1990 eclise gs turbo. the problem is, it wont hold a steady idle. when you rev it up to 2000 rpms or more and try to hold it, it revs up then cuts out. it wont stay there. i have replaced the plugs, wires, fuel filter, ignition control mod, coil pak, air flow meter, and cleaned the injectors. nothing works. any suggestions?
RE: please help (newbie)
Have you checked all vacuum hoses for leaks, cracks, or breaks?
usually it will have to do with the ISC motor but i would start with the vacuum lines. Also check out www.vfaq.com for a write-up on the fluctuating idle faq
