rear wheel stickin out
So here is the problem :P
My right rear wheel is stickin out about 1cm (little more than a 1/4 inch) more than my left rear wheel I have been searching around the web for some answers but without any luck btw the rims and tires are the same so its not that ... does any one else have this prob or is it only mine... //Christopher |
RE: rear wheel stickin out
it is crooked or straight? does it drive good?
Im guessing a shock or a spring. I think what you are refering to is negative camber.
Hi
The car goes strait and all and the tire is evenly worn down hmm i have found a few topics in other forums with the same problem same wheel and all but with no replies Thanx for the replies Sry 4 my broken english :/ |
Its definetly something in the suspention. Depends if its a shock or a spring, or possibly something else that is bent. Maybe just an alignment issue.
The car is lowerd with yellow koni shock and unknown springs
il take some pictures of what ever u want me to to make it esier to solve the prob because its anoying as h**l u know what i meen ... Hope i can solve this prob soon because i have another engine on the way from the US it will arrive in a few weeks or so ;) I have the 4g63 engine (150hp 7b one) in mine now and when the new one arrive it will be a 4g63t with the same spec as evo3(240bhp) :D yummy!! so it will become a 1g gs-t and when that is done il be on the hunt 4 some parts to make it an gsx and oh yes i know it will cost me alot and alot of work but i want to do it btw is galant rear axel (the 4wd one) the same as gsx?? I know i got carried away there :p |
Your camber is off.
