safc settings
I just installed my safc and I was wondering what settings I should start my tune with? Any info or links would be great.
Thanks |
RE: safc settings
you +/- % on your tuneing or the stup stuff? what mods do you have? any fuel upgrades?
RE: safc settings
I meant the +/- but I got it wired in and it wont turn on.... My car is running really rich and barely stays running. I followed the instructions on vfaq.com to the "T" except my ground wire didnt have orange bands on it... I just connected it to the corresponding pin... Please help!
RE: safc settings
ORIGINAL: 92_laser I meant the +/- but I got it wired in and it wont turn on.... My car is running really rich and barely stays running. I followed the instructions on vfaq.com to the "T" except my ground wire didnt have orange bands on it... I just connected it to the corresponding pin... Please help! basicaly make sure the pink and orange wire are on the right section of the factory wire and no connected all together [IMG]local://upfiles/3652/A14B73CDDD1E4EB68D7334E42D60C549.jpg[/IMG] |
RE: safc settings
Got it to work. The plug inside the afc was unplugged... Now my car wont start or run at all. These are my settings
1G Turbo 16G 2g mani/full 3in exhaust intake mbc 11psi .... Im pretty sure thats it.... Low Setting: 1K +19 2K +12 2.5K +9 3K +6 3.5K +5 4K +5 4.5K +5 6.5 +5 High Setting: 1K 0 2K +3 2.5K +3 3K +4 3.5K +4 4K +4 4.5K +4 6.5K +8 Th-Point Lo 30% Hi 80% Thanks |
RE: safc settings
ORIGINAL: 92_laser Got it to work. The plug inside the afc was unplugged... Now my car wont start or run at all. These are my settings 1G Turbo 16G 2g mani/full 3in exhaust intake mbc 11psi .... Im pretty sure thats it.... Low Setting: 1K +19 2K +12 2.5K +9 3K +6 3.5K +5 4K +5 4.5K +5 6.5 +5 High Setting: 1K 0 2K +3 2.5K +3 3K +4 3.5K +4 4K +4 4.5K +4 6.5K +8 Th-Point Lo 30% Hi 80% Thanks Here is what it said for the EVO: In the Th-Point section of the S-AFC, set the low trigger around 25%, and the high trigger around 65%. In the NePoint section, set them to; S-AFC: 1k, 2k, 3k, 4k, 4.5k, 5k, 6k, and 7k,. S-AFC II (adjust your points where needed): 1k, 2k, 2.6k, 3k, 3.6k, 4k, 4.6k, 5k, 5.6k, 6k, 6.6k, 7k again it needs to be on Karma or the car wont run right if at all |
RE: safc settings
I reset the safc and set it to karman and tried both 4 and 2cyl but no change. Is it the pink or orange wire that should be connected to the ecu plug? If its set to 0 accross the board it should run stock, right? Throttle is set at 10% low and 50% high....
Thanks |
RE: safc settings
My throttle points were too low... It wasnt getting enough fuel to start. Now I just have to go log a few runs and do some tuning... then I can install my 560 injectors and turn up the boost just to tune it again.
Why do we love the cars soooo much? What the h3!! is wrong with us?? |
RE: safc settings
ORIGINAL: 92_laser I reset the safc and set it to karman and tried both 4 and 2cyl but no change. Is it the pink or orange wire that should be connected to the ecu plug? If its set to 0 accross the board it should run stock, right? Throttle is set at 10% low and 50% high.... Thanks maybe my drawing of it will help.... I didnt know what color the factory wire was (I forgot) so I used green but you should get the idea [IMG]local://upfiles/3652/3C567A2A9EEB47988C60DFC5BC710817.jpg[/IMG] |
RE: safc settings
ORIGINAL: 92_laser My throttle points were too low... It wasnt getting enough fuel to start. Now I just have to go log a few runs and do some tuning... then I can install my 560 injectors and turn up the boost just to tune it again. Why do we love the cars soooo much? What the h3!! is wrong with us?? |
| All times are GMT -5. The time now is 09:07 AM. |
