safc settings
Ok, all my settings were are to zero and I even drove it around town for about ten minutes.... But now it wont start again!! I think it might be the plugs so I am gonna change them today. Anyone have any suggestions?
Thanks
Thanks
maybe the pin out you copied from was wrong and you spliced into the wrong wires? I know with mine there was a small note edit on the bottom saying that one pin was wrong and it said where the correct pin was but mine was only for the RPMs signal
well i know that when me and emonz did his it would work for allitle and then after about ten minutes or so it would wrong horribly. We found out that it was the wiring. I would just double check your diagram and make sure everything has a good connection.
