The sound of water behind the dash... any idea how to drain this?
I'm hearing what sounds like water sloshing back and forth from what seems to be behind the center of the dash (behind the stereo and temperature controls area). This occurs mostly when I take a hard turn and it even spilled out once on to my feet as I took a very hard right turn off of a highway exit ramp. Anybody know how or if I can drain this water out and if so where would I find a drain plug? Thanks for any help!!
RE: The sound of water behind the dash... any idea how to drain this?
I had this problem when I replaced my rad hoses(2g GST) and didn't top up the coolant. Make sure you have enough coolant in the system and bleed it, see if that fixes it. The sloshing noise was hilarious.
Thanks n0c7. I just changed the radiator and the hoses and the problem still remains. I also believe that the coolant is topped up and bled properly. It might also be important to note that I was also having this problem BEFORE these changes were made and I thought it might be corrected afterwords, but no such luck. Any other suggestions?
HOW ABSENTMINDED OF ME!! I never even mentioned the make of the car!! It's a 94 Eclipse 1.8L. THANKS!!
Heater core?
Is it water or coolant?
if its coolant, you have a heater core leak and need a new heater core. if its straight water (no antifreeze) its probably from your ac evaporator drain; the drain hose is probably plugged up.
Thanks everybody for all of your replies. Estraw, I though of the heater core but it is definietly straight water. How do I access the A/C evaporator drain hose in order to unclog it? Thanks again.
