turbo queastion
I never tried but asking with the turbo installed in car will it spin freely?
RE: turbo queastion
like if it is still on the car and you take off the intake pipe can you spin it? yes you should be able to.
RE: turbo queastion
Yes it should.
RE: turbo queastion
guess i'll have to start my look for a upgraded turbo sooner than i though mine wont spin i'm wondering if that would have cause the timing belt to brake?
RE: turbo queastion
Nope that wont make the belt break.
RE: turbo queastion
I figured out the timing belt brake issue the guy that gave me the car rebuilt the motor last year and use the old timing belt on it.
RE: turbo queastion
what do you think
[/align] http://i12.ebayimg.com/04/i/000/ea/71/83b0_1.JPG EVO3 td05 16g Turbo Kit with dsm flange- Turbine wheel=49/56mm TRIM:77 Compressor wheel= 48.3/68mm TRIM:50 .70 A/R housing[/align] |
RE: turbo queastion
Where is that kit from?
RE: turbo queastion
local speed shop i think it's junk though. what's the differents in the t4/t5 and the 16g and i think i've seen a 20g and 25g
RE: turbo queastion
i found a nice t3 a friend of mine has looks good no shaft play has the same oil and water lines that mine has.
