Wont shift?
I just got a 91 tsi AWD AUTOMATIC. It is at the shop to be inspected and have a tranny service tomorrow. I went to test drive it for the first time and it acts like it is in 3 or 4th gear. Like it has to get up to about 2k+ before it will move and it NEVER shifts and i got it up to 70. At 70mph it was at 4,400rpm. Also until it gets to 40mph it just sticks at 3000. What is going on? it has 120,000ish miles
RE: Wont shift?
It might be the tcu stuck in limp mode. So when that happens I think it only has 3rd gear and reverse. I am not 100%sure, someone correct me if I am wrong.
RE: Wont shift?
how would i find out? Can i fix it?
RE: Wont shift?
I really dont know alot abt the tcu's in these cars. If you found one try swapping it to see if it works or not. You could look on ebay for one or go to a local junkyard.
RE: Wont shift?
my rpms are limited at like 3000. WTF is going on
RE: Wont shift?
Do you know anyone w/ an auto dsm, see if you could borrow their tcu or something. Deffinatly sounds like a tcu since your stuck at 3000rpms. I also remember hearing that sometimes the shift solenoids get stuck, causing the tranny not to shift. Just an idea.
RE: Wont shift?
i got a second tcm cause i had been building up a fwd till i got the AWD
RE: Wont shift?
Are they the same tcu #?
RE: Wont shift?
uhhh nooooo .......... that means it wont work huh? I put it in the awd and the f*ckin thing wont start. It has fuel in the rail but i guess no spark
RE: Wont shift?
i put the stock one in and it started
