-   -   "T" with MBC (https://mitsubishiforum.com/forum/2nd-generation-63/%22t%22-mbc-24244/)
SPYDER97RED Dec 23, 2007 05:47 PM
"T" with MBC
if i use the wastegate actuator and the compressor housing then what about the little cube shaped "T" fitting that came with the MBC? and also there is an arrow on the MBC and it says "the arrow points toward wastegate actuator" but on mine it is on the bottom nipple on the MBC and the arrow is pointed away from the nipple, ive seen pictures of this MBC with the arrow pointed toward the nipple and others with it pointed away like mine. ok so the top nipple (inlet)goes to the turbo housing and the bottom nipple (outlet) goes to wastegate. right.
tjbiker031 Dec 23, 2007 06:53 PM
RE: "T" with MBC
dude, you do not need to start a new thread every time you have a new question thats related to your last 3 threads. and theres directions EVERYWHERE ON THE INTERNET!!!!!!! if there wasnt any in the box. and if you cant understand how to hook up a MBC then take to to a shop.
TheEngineer Dec 23, 2007 08:08 PM
RE: "T" with MBC
this question was just answered in another thread. Look at www.vfaq.com
