A\C System Engine Throw Codes
Hey guys, what engine codes could be thrown with the a\c to a 1999 mitsubishi eclipse rs? Due to my car a\c works but it is not really cold thinking it might be the compressor not turning on.
RE: A\C System Engine Throw Codes
These are the OBDII engine codes pertaining to an A/C system
P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance P0532 A/C Refrigerant Pressure Sensor Circuit Low Input P0533 A/C Refrigerant Pressure Sensor Circuit High Input P0534 Air Conditioner Refrigerant Charge Loss Is your check engine light on? If it is then just go to autozone or something and have them run the code |
If you pop the hood while the car is running and listen to the compressor you should be able to hear it switch on. Of course somebody else will have to press the A/C button. If the compressor turns on then you might have a leak in the A/C system somewhere.
where is the a\c compressor relay located in with a 420a engine? Also, if it is the compressor not turning on, should i replace the relay or do i know that i have to get another compressor?
| All times are GMT -5. The time now is 07:34 AM. |
