1995 GS-T Speedometer stopped working???
Old May 19, 2005 | 05:19 AM
matt02708's Avatar
Default 1995 GS-T Speedometer stopped working???
My Speedometer needle dropped. It has been acting up for about a week now kicking in and out and it finally went. How will i know what needs to be replaced? Sensor, Cable, Dash Cluster, Stock wiring???
Old May 19, 2005 | 02:10 PM
Mover1799's Avatar
Default RE: 1995 GS-T Speedometer stopped working???
I have a 95 Eclipse GS and the Speedometer is 10 mph off! Wonder how u can fix that problem
Old May 19, 2005 | 03:10 PM
get435's Avatar
It is 10MPH off dose it have rims and tires? did it have rimes and tires? you can go to a place that sells tires and stuff and they will re calibrate the system so it reads the right speed.
Old May 19, 2005 | 04:48 PM
pc's Avatar
pc
Matto2708,
If you have a needle does that mean the speedo is all mechnical? If it is it could be either the cable, the gear in the trans or the gear in the gauge. Only way to find out is the take it apart and find out. I would disconnect at the trans. 1st and if all looks ok there, take out the dash and inspect. I would imagine that the unit behind the dash is the most likely. If there is a speed sensor in the gauge and all the mechanical looks ok then just replace the sensor. Sometimes the inner cable will break, that's easy to find.
Old May 19, 2005 | 08:35 PM
Sanguinius's Avatar
If the inner cable breaks then he'd have more than a 10 MPH difference. probably wouldn't have a speedo at all. I think it's more likely a sensor problem or a problem with calibration.
thutch
Jun 25, 2010 11:30 AM
metalsaber
May 31, 2007 07:45 PM
wiggerman8860
Nov 27, 2006 07:25 PM
95eagletalon
Oct 8, 2005 02:17 AM
3000GTSL
Jul 27, 2004 10:42 PM
