1998 GST turbo question??
Old Feb 17, 2006 | 01:21 AM
tddavis's Avatar
Default 1998 GST turbo question??
I recently bought a 1998 GS-T Eclipse and want to know how to find out what kind of turbo is in this car. The dealer I bought it from didn't know too much except it wasn't stock. I know how dumb could we both be but still I have the car and want to know what kind is on it. It looks kind of big compared to others I have seen. Any help would be great. Thanks,
Old Feb 17, 2006 | 02:33 AM
player69x's Avatar
Default RE: 1998 GST turbo question??
it should have the code on the turbo. but you probally gonna have to get it on a lift and look underr the bottom.
Old Feb 17, 2006 | 08:03 AM
take a picture of it we can tell you if its stock. get the #s off of the compressor housing as well
Old Feb 17, 2006 | 08:54 AM
domestickilla's Avatar
stock=T-25 first gen swap=14B other than that i have no idea without a code
Old Feb 17, 2006 | 03:50 PM
ORIGINAL: domestickilla
well stock 2G turbo is the T-25 but the T-28 uses the same housing correct
and the stock 1G is a 14B which uses the same housing has a small 16G. the compressor housing just faces different on these than the T25 does
Old Feb 17, 2006 | 06:12 PM
TheAdvocate's Avatar
Gonna definately need a picture... Is it still the stock exhaust manifold?
Old Feb 19, 2006 | 11:18 PM
wicked_outlander's Avatar
am' guessing its a t28....lolz
Old Feb 19, 2006 | 11:29 PM
ORIGINAL: wicked_outlander
T28 uses the T25 housing so it would still look stock...im guess it is still stock becuae no one upgrades a turbo with out fuel system, piggy back at least, and a hand full of other supporting mods. plus if it were a 14B housing that is easy to tell the difference on a 2G.
Old Apr 3, 2006 | 04:58 AM
tddavis's Avatar
The only thing I found on it was a/r .60 and f2211... Let me know if that helps...Thanks
Old Apr 3, 2006 | 11:04 AM
well the a/r 0.30 has to do with the compressor sizing. Im not sure what the f2211 means though
After looking into this into more detail that is a very small A/R ratio. I am going to have to say that MUST be either a stock turbo, or a t28 since i think they both used the same compressor
