1G in a 2G PART LIST?
Ok so is all i need to but a 6 bolt bottom end to a 7 bolt top...i just want to know before i buy some of the parts?
Parts List · 1G CAS (91-92 Optical Effect, 93-94 Hall Effect) · 1G Oil Cooler (90-92 MD 157670 6bolt water cooled oil cooler) · 1G Water Pump · 1G Oil Pump/Front Case · 1G Timing Belt necessities · 2G Engine mount (modified) use 2G engine mount trimmed, with 1G tensioner arm · 1G Timing Belt Covers (modified) · 1G 90-92 6-bolt block (with whatever internals) · 1G 6-bolt Flywheel · 2G Starter Mounting bracket · 1G Water Pipe · 1G lower radiator hose · 1G Thermostat housing/ Water Neck · 1G 6-bolt oil pan Balance shafts (remove them or keep em, its up to you, we take them out) · 2G Alternator · 2G Power Steering Pump · 2G A/C 2G Belts |
RE: 1G in a 2G PART LIST?
can someone move it to 2 gen eclipse...thanx
I need to be a mod |
ORIGINAL: 50ul }{4ck3r can someone move it to 2 gen eclipse...thanx I need to be a mod |
LMMFAO bruno.....i dont drink all that much no more...have a job too keep me from it
yup your list looks exactly like the one magnus motorsports has copy and paste it here to make it look like your own thoughts nice i like your style but magnus is correct that is all your going to need. i've done the swap already and in the process or putting an entire 1g top and bottom in my 2g good luck bro.
lol anthony it is not my own thoughts....i was just seeing if it was all correct
i think they make a kit from Buschar Racing if you are intested in just buying everything at once.
RCJr9186 can you put up a link to that? I couldn't find it on their site. Thanks
there is the link for the site....but need link to complete kit
