2g aftermarket radio grounding
RE: 2g aftermarket radio grounding
Good to hear you got it all wired in and done. A bad ground will ususally cause your radio to have power spurts. It can kick on and off. I think you could have a bad signal too if the ground isnt too strong. But the main problem is the powering issue.
you know whats funny ... i took advantage of the free installation @ best buy, and they told me they didnt make pockets under the stereo for the 99 gsx models.
but good work though. looks better than my ****.
ORIGINAL: antlip
I replaced the factory radio thinking it was the problem, but even with the new radio, I still only get a couple stations if that. The antenna works and goes up properly, but I'm just not sure why the reception is that bad. Could the antenna itself be bad/faulty? If so, how would you check?
ORIGINAL: GSXEX Knubbe
ORIGINAL: Kaede.Noir
what pocket are you guys talking about? that black box where you unconscioulsy put all your sh*t in?
I don't know if you guys know this...I'm sure y'all do...but the aftermarket dash kit with the pocket has a tiny opening. It's about the size of an empty wallet. When I had mine, I don't think I could have stuck 2 CD cases in there one on top of each other. The Bosch one had a slightly larger pocket, but still smaller than the stock pocket. The stock pocket has a full din size opening. Just FYI
spc_76
07-01-2005 10:59 AM
