400hp turbo
Old Dec 14, 2006 | 09:04 PM
paintballproam's Avatar
Default 400hp turbo
I'd really like to get my car up to 400hp or more. In a couple weeks I will have my built 6 bolt in along with some HKS cams. Right now I'm just running a Big T28 but im obviously going to upgrade it. Now in order to get 400hp what am I going to need? the motor is already built to take it so no worries there. Here is what i have so far figured out
DsmLink
780cc injectors (or bigger?)
255lph pump
FPR
50trim turbo /FP green(or bigger)
FMIC
its a 1995 eagle talon tsi awd
so far the car already has
ACT Flywheel
ACT 2600 clutch
Tubular stanless manifold
Big T28 turbo w/Evo III o2 housing
Greddy IC pipes and RS BOV
1g intake manifold
BBK 62mm throttle body
3"turbo back exhaust
Intake
and of course the 6 bolt motor.
Now im not going to do this right away, im just thinking and trying to plan ahead. Im pretty much looking for some kind of chart, showing The name of the turbo, the peak horse power, the horse power it can do every day ( like not pushing it to its max), and spool up time
I want good power, but i dont want to wait till 5k rpms to have it
Old Dec 14, 2006 | 09:06 PM
Default RE: 400hp turbo
If you want a little better... you should go with the AEM EMS for tuning.
You will need a FMIC.
Your getting a 2.3L stroker right?
Old Dec 14, 2006 | 09:08 PM
i just said dsmlink cuz it was the first thing that came to mind. No im getting a built 2.0l
Old Dec 14, 2006 | 09:10 PM
Ok so you want to stay somewhat small then... hmmm il do a little research and make a post again soon.
Old Dec 14, 2006 | 09:16 PM
Ok... what about a GT30R or a 20G. I like the SBR bastard 20g... nice turbo. I also found this... not sure what you think of it and im not 100% sure as to what the specs are. LINKY TO TURBO
yea im thinking MAYBE a 50 trim. Or a FP Green or FP 3052
Old Dec 14, 2006 | 09:17 PM
Read my post ^^
Old Dec 14, 2006 | 09:18 PM
is that like a BB 50 trim? GT30R sounds good, not sure if the 20g will do it tho
Old Dec 14, 2006 | 09:20 PM
The 20g should do it... but it would be at its max. They say you can break into the 10s with it.
Um thats a dual bb 50 trim.
Old Dec 14, 2006 | 09:23 PM
what do you think the spool up times are?
