4G63 Swap into an rs??
Old May 17, 2005 | 12:39 PM
get435's Avatar
Default RE: 4G63 Swap into an rs??
as long as your vin number is on the car and not any other cars any swap should be "legal". the emmisions is where us 2g people get screwed because the downgrade to the obd1 from obd2 throws all the emmisions off. if the OEM ecu works with he motor you should be fine.
Old May 17, 2005 | 01:17 PM
DSMTalonAWD51's Avatar
once again, in almost every state it is technically illegal to put an older motor into a car. some smog guys wont catch it, others will. If they do you will NOT pass visual whether you pass emissions or not. I have a 6bolt in a 97 gsx, using OBDII still, I have dangling wire harnesses that are no longer used, and will not pass, i have to get smogged illegally.
Old May 17, 2005 | 06:06 PM
patsevo8's Avatar
Yes the only reason that any inspector would see that it's a swap is by seeing dangling harnessess or if you mention it. I've never met an mechanic or tech that new I had a swapped engine. No one can really tell.
Old May 17, 2005 | 10:10 PM
T88Spyder's Avatar
So If I swapped it and got rid of the dangling harness it would most likely pass the visual???
Old May 18, 2005 | 12:41 AM
Sanguinius's Avatar
It all depends on how strict the inspector you go to is.
Old May 18, 2005 | 02:59 AM
T88Spyder's Avatar
well i know people who smog cars
Old May 18, 2005 | 12:21 PM
T88Spyder's Avatar
Either way it would be more ideal to just suck it up and purchase a Gst/Gsx am I correct?
Old May 18, 2005 | 02:52 PM
you got it
Old May 18, 2005 | 08:40 PM
Sanguinius's Avatar
Yep it'd be easier and cheaper to just suck it up and buy GST/GSX
Old May 29, 2005 | 01:42 AM
FireDoc's Avatar
If you go to www.slowboyracing.com they have 420A turbo kits. At least last time I checked.
SCOOT3R
Sep 9, 2006 11:30 AM
fido_dido83
Jul 23, 2006 04:47 PM
codeprez
Jun 21, 2006 03:57 PM
andauto
Feb 25, 2005 02:18 AM
