4g64 low oil pressure at idle
hi , rebuilt a 4g64 , new conrod and main bearings , new oil pump, new oil pressure switch,. and balance shaft removal kit installed.
yet at idle the oil pressure light comes on, and when it does , there is NO noises at all coming from the engine, but as soon as you bring the revs above idle the oil press light goes out. is there a way to increase the oil pressure ?i was thinking with the spring/plunger setup where the oil filter screws on ? thanks, mark k |
Originally Posted by turbo1600
(Post 280419)
yet at idle the oil pressure light comes on, and when it does , there is NO noises at all coming from the engine, but as soon as you bring the revs above idle the oil press light goes out. is there a way to increase the oil pressure ?i was thinking with the spring/plunger setup where the oil filter screws on ? thanks, mark k I have the same problem with a 2006 Galant 2.4L. Changed the oil Switch. The Road Bearings, the Main bearings, the battery and still the oil light comes out at idling. called a mechanic he tighten some vacuum hoses and say tha I can drive the car like that, because it dosent make any strange noises but Id like to get more answers do guys have clue of whats going on? |
