6 or 7 bolt?
hey im back with yet another quick question. ok my 97 GST got the 4G63 engine in it. the 2 g's are the 7 bolts and the 1 g's are the 6 bolt right? im thinking about rebuilding my engine soon and i want to make sure that i got the 7 bolt, im sure i do but i just wanna make sure.
RE: 6 or 7 bolt?
Well i can tell you right now that you do.
90-93 had the 6 bolt... and the 94 (still a 1g) had the 7 bolt. That is a common mistake! 94-99 had the 7 bolt. |
RE: 6 or 7 bolt?
yea umm i wouldnt rebuild your 7 bolt. Buy a 6 bolt and build that up they are the good ones
RE: 6 or 7 bolt?
well im kind of new to Mitsu's. whats the difference between the two?
RE: 6 or 7 bolt?
ORIGINAL: Sebba Well i can tell you right now that you do. 90-93 had the 6 bolt... and the 94 (still a 1g) had the 7 bolt. That is a common mistake! 94-99 had the 7 bolt. |
RE: 6 or 7 bolt?
I was always told it was 93.5+ that had the 7 bolt.
I wouldnt swap the 6 bolt in. I just dont think its worth it... unless you plan on keeping the car for another 150k miles? |
RE: 6 or 7 bolt?
It refers to the number of bolts that attach the flywheel.
The 7 bolt has a problem that is called 'crankwalk' its not massivly common but it destroys the engine. Some 7 bolts never experiance it.. and some do. There is no way of telling. The 6 bolts are a little stronger.. and dont get crankwalk. But it is expensive to swap the 6 bolt into a 7 bolt car... like... 3000 expensive.. not including the cost of the engine. |
RE: 6 or 7 bolt?
ORIGINAL: Sebba I was always told it was 93.5+ that had the 7 bolt. I wouldnt swap the 6 bolt in. I just dont think its worth it... unless you plan on keeping the car for another 150k miles? |
RE: 6 or 7 bolt?
i know its a stupid question and probably explained it a billion times but what is "crankwall"?
RE: 6 or 7 bolt?
ORIGINAL: Sebba It refers to the number of bolts that attach the flywheel. The 7 bolt has a problem that is called 'crankwalk' its not massivly common but it destroys the engine. Some 7 bolts never experiance it.. and some do. There is no way of telling. The 6 bolts are a little stronger.. and dont get crankwalk. But it is expensive to swap the 6 bolt into a 7 bolt car... like... 3000 expensive.. not including the cost of the engine. Where is silvercoupe we can ask how much he swap was and Ibet its not as expensive as youd think |
| All times are GMT -5. The time now is 06:52 AM. |
