94 TRANNY ONLY GOES INTO REVERSE
Old Aug 15, 2004 | 09:47 AM
SOMEONEWITHNOSINCE's Avatar
Default 94 TRANNY ONLY GOES INTO REVERSE
HEY GUYS KIND OF NEW TO THE ECLIPSE SCENE MY SISTER JUST GOT A 94 ECLIPSE AUTO FROM A COUSIN BUT IT ONLY GOES INTO REVERSE,NONE OF THE OTHER GEARS WILL ENGAGE. SOMEONE SAID THAT THE TRANSMISSION FLUID COULD BE TO THICK IS THIS POSSIBLE AND IF SO,ILL CHANGE IT BUT ALSO THEY STATED THERE IS SOME TYPE OF FILTER FOR THE AUTO TRANNY AND IF SO HOW DO I GET THE FILTER OFF TO DRAIN ALL THE BUILT UP TRANNY FLUID LEFT AFTER I DRAIN MOST OF THE FLUID FROM THE TRANSMISSION
Old Aug 18, 2004 | 06:43 PM
jdmeclipse92's Avatar
Default RE: 94 TRANNY ONLY GOES INTO REVERSE
if its an automatic then the clutch packs are shot, it could be that the gears are stripped, if its a manual the syncros are gone, hope it helped, by the way if you rebuild the tranny put a shift kit on it cause the pre-95 trannys are WEAK
sponky
Jun 9, 2014 01:38 PM
tdf
1st Generation
13
Nov 24, 2011 07:49 PM
chrissiri
Sep 29, 2009 09:08 AM
Drizzo
Feb 18, 2006 01:31 PM
