95' Eclipse, dash/guage questions....
Old Nov 17, 2011 | 11:07 PM
Wendwarf's Avatar
Exclamation 95' Eclipse, dash/guage questions....
I'm wondering and hoping that someone is willing to help me with this. Haha. My 95 Eclipse's speedometer doesn't work, everything else in the dash is fine. I'm told it's a sensor that's around $100. Either way, the question is. Is there anywhere and any type of dash and guage set other than the stock ones? Thanks a ton guys!
Old Nov 19, 2011 | 08:33 AM
_93TSI_370+K_'s Avatar
If it is a analog speedometer, either the cable broke or the cable got disconnected somehow from the speedometer or the transmission.
Old Nov 20, 2011 | 02:06 PM
Wendwarf's Avatar
It is an analog, the year is 1996 however. How can I check the things you have mentioned, sir. Thanks for the help!
Old Nov 20, 2011 | 08:36 PM
First and maybe the easiest on your vehicle is to find the speedometer cable that is attached to the transaxle differential. This cable goes into the firewall right in back of the instrument panel. It is a pretty rigid cable. If you can disconnect the cable from the transaxle, you should be able to spin it and with another person watcing the speedometer, it will tell you if the cable is broken. You may have to spin the cable left or right to get movement on the speedometer and you may have to spin it somewhat fast. This drive cable can be pulled out of the outer cable and both ends of the drive cable should have squared ends. If it comes out and the other end is not square but is broken, you will have to remove the dash to get the broken piece from the speedometer side of the cable. Then it is just a matter of getting a replacement drive cable and replacing it.
I think you will be able to get to this cable, without going inderneath the vehicle, but if you need to raise the car to get under it, PLEASE make sure you use appropriate equipment to keep the car up, before you go under it..for any reason. I've has a neighbor get crushed by his car when he jacked the car up just to inspect the shocks, and the jack failed.
Old Oct 31, 2014 | 03:15 AM
shadowshade's Avatar
I have a 95 eclipse gs non-turbo and both the speedometer and odometer dont work I have tested the speedo cable and it works fine and now I dont know what to do can I have some help please
gobbler33
Dec 18, 2006 08:47 AM
kobalt
Mar 17, 2006 07:19 PM
mitsunoobie
Mar 11, 2005 11:15 AM
hellcat51
Sep 8, 2004 06:42 PM
mitsu23
Nov 2, 2003 07:19 PM
