95 eclipse gst fuel filter
i was wondering if i was able to replace the stock fuel filter with regular fuel filter with rubber hose while i have my engine out, just to make it alot easier to change in the future, please let me know thanks
WOW.... nobody knows about doing this??
no one would want to do this. the reason for the filter is to protect the fuel injection system i personally don't want to have to buy new injectors just to save a few minutes on a 7-8 hour job
depends what your goals are... You can get and earl's filter if you're going to use -an lines... but its up to you.. The earls filter is definitely easier to replace than the stock one.... again.. up to you... just make sure your replace the copper crush washers when you replace the stock filter or it will leak fuel all over the place.
oh ok kool, i guess the guy above us didnt read it right... of course im not gonna run my line without a filter..
| All times are GMT -5. The time now is 10:19 AM. |
