95 Eclipse P0100 Code help
Well I am working on a 95 Eclipse 2.0L Turbo Car that I have a Issue with and am pulling P0100 Code. Cehcked the wiring from PCM and am receiving the 12v, Ground trigger, & 5volt. Appears the MAF sensor or connector is bad. After doing some research it appears this car should have a 609 MAF and what is in it is a 055 sensor. Anyone have any thoughts on the problem that I am overlooking and how to identify what is the correct MAF sensor?
