95 gsx trouble plz help
i just purchased a 95 gsx a few days ago, and the day after i bought it i was driving home from work, the oil pressure guage went all the way down, and the temp guage went all the way up and it stalled. I added oil which made the pressure go up slightly, and drove it home (which was about 2 miles from the stall). That night once i shut the car off, it wouldnt restart. The next day, it started fine, backed it up to find a pool of fluid underneath. I added oil to it and left it running, then came out 5 mins later, and moved the car forward. virtually all the oil i added was sitting on the ground. It makes a sqealing type noisewhen i start it, but then it stops. The oil pressure guage goes up to about half now. i havent driven it since the incident. If i look directly at the engine block, right below the DOHC symbol, there is a metal tube of some kind coming from the engine, and that is where the oil is streaming out at a steady pace. I do not want to drive it for fear of engine damage. does anybody have advice? thanks alot</P> </P> Tom</P> |
i'm not sure, but i think that may bean oil line going to the turbo. Look at your turbo and see if there are any disconnected fittings or anything. But don't qoute me on this, i may be thinking of something else. Hope this helps.
check the turbo man........im with the spyderGs guy on this one....
