95 rs motor swap
Old Mar 20, 2010 | 09:06 PM
dub_city1021's Avatar
Default 95 rs motor swap
i have a 95 eclipse rs... i am swappin the motor out with another one that i got off a friend of mine that has head work done to it... any suggestions on the easiest way to do it?
Old Mar 20, 2010 | 09:52 PM
3000gt16's Avatar
Well first off, it is another 420a correct? Swappin a turbo motor would be complete hell, almost anyone here will tell you it aint worth it. If its the same motor, what all do you need to know? Easiest way would be in a shop if you dont have experience in it imo but what specifically do you need info for?
Old Mar 21, 2010 | 02:19 PM
what do you mean easiest way....like to remove the engine? Do you have a engine lift?
Old Mar 26, 2010 | 04:34 PM
i might be able to get a lift... but at the moment no... i was figuring to drop it out the bottom... yes its another 420...
Old Mar 27, 2010 | 07:55 PM
how are you gonna jack the car up high enough to do that?
Old Mar 30, 2010 | 08:48 PM
JesikaRV's Avatar
I chain the puller to the car lift the car then use jack stands to keep it up while I hook the chain to the motor and drop it down through the bottom.
LizziVr4
Oct 25, 2008 09:49 PM
Ralliart3000
May 21, 2008 07:13 PM
mitsubu
Oct 3, 2005 08:36 AM
1sickeclipse
Jul 2, 2003 12:55 AM
