95rs vs 99rs
Old 11-28-2005, 10:42 PM
white99rs's Avatar
Default 95rs vs 99rs
why is my friends 95rs faster then my 99rs there both stock my car can only hit 90 in 3rd and he hits 100mph what going on my car has way less miles 37k and his has 55k was the 95 faster or what.
Old 11-28-2005, 11:01 PM
white99rs's Avatar
Default RE: 95rs vs 99rs
is it weight? i beat him in a reace but i was wondering y he hits 100 in 3rd and i hit only 90mph?
Old 11-28-2005, 11:25 PM
Joel_CA's Avatar
If you both have the same engine and are both reving at the same RPM's in 3rd gear- there must be a gear ratio difference in your transmissions. You're lower speeds indicate closer ratio's which might give you the edge in accelleration.
Joel, CA
Old 11-28-2005, 11:36 PM
slow420a's Avatar
let me guess yours is stick and his is auto? The auto tranny is slower then the 5spd, like said above the gear ratios are different, along with the redlines and shift points. The 95 is a little different than the other years. It has a different ecu program than any of the other years, it uses a system similar to the 4g63's. The ecu does not apply fuel cut, They are missing a cam positing sensor(if i rember correctly). Also it features a return line fuel system and the crank and bearings are different. And for some reason the 95 mtx ecu cook themselves. besids that its the same.
Old 11-29-2005, 12:01 AM
white99rs's Avatar
ahh i forgot to mention that there both 5spd at 7k i hit 90 and in his car at 7k he kits 100?
Old 11-29-2005, 12:03 AM
white99rs's Avatar
maby he needs his spdo is off and needs to be ajusted.
Old 11-29-2005, 12:05 AM
slow420a's Avatar
thats possible, the 420a was in a bunch of cars, being that its a bit older their is a chance that he may have acquired a neone tranny, different gear ratios but same final drive.
Old 11-29-2005, 12:11 AM
slow420a's Avatar
Also you shouldent shift at the red on a stock 420a, the car dosent make enough power at that high of a r. I know its stupid try racing him again and shift 1st gear at 6, 2nd at 62 and third at 66. I bet you will pull on him a bit more.
http://media.putfile.com/eclipse-14-mile-run-slow
Old 11-29-2005, 12:12 AM
white99rs's Avatar
then do i have a mitsu. tranny?
Old 11-29-2005, 12:21 AM
white99rs's Avatar
yes i know my car is slow......
i have a 98rx7 but its put away for the winter.
Quick Reply: 95rs vs 99rs
