'96 Eclipse owner?
Old Aug 18, 2005 | 03:54 PM
Superman369's Avatar
Default '96 Eclipse owner?
Hey i'm lookin at buying a 1996 Eclipse RS. It has a few problems. Back-up lights don't and neither do the flashers. it has an AEM cold air intake 76,xxx miles on it for $5k. it's rollin on 17" rims brand new tires, clean body needs timing belt changed. Any advice would be greatly appreciated. Plus if their are any other issues i should be concerned about.
Old Aug 18, 2005 | 05:13 PM
get435's Avatar
Default RE: '96 Eclipse owner?
you have alot of labor ahead for 5g. i hate the timeing belts they are biatch to change also if the belt needs changed so dose the water pump around 200-300 bucks. as for the blinkers if they dont work before you buy check and see if it is the fuse if not than it may not be worth it becuase electrical sucks to pinpoint and it may be worse than just a short.
Old Jun 20, 2012 | 10:43 PM
illshot's Avatar
I dunno 5k sounds too high.
Zequel
Dec 26, 2014 01:40 AM
IndyEndeavor
Jan 10, 2013 07:01 AM
rgsoundguy
Aug 15, 2008 12:00 PM
Mover1799
May 19, 2005 02:08 PM
Ra11iartEclipse
May 10, 2004 09:23 PM
