97 signal lever wont stay in position?
is this a hard fix, Im afraid I wont pass inspection .
RE: 97 signal lever wont stay in position?
Just hold it down when you want to turn. Go to the junk yard and pull one and replace it. easy fix.
It wont stay in either pos.? Like niether left nor right?
a little more information please........... that is very vague. is it stuck on a turn? stuck in the middle? won't stay in a certain postion?
works in left/right but wont stay in right must hold :), NY is very strick on inspections :(
I just wonder if I have to pull the wheel? |
Replace the multi function switch.
Its simple. Just undo the 2 trim panels around the steering wheel, disconnect the switch, unbolt it, then do the reverse to install. Switch is probally $30-40 at a dealer. |
