97 Spyder, needs tons of HP!, Help with suggestions
Old 12-04-2005, 11:47 AM
Default RE: 97 Spyder, needs tons of HP!, Help with suggestions
Ya.. He never said it was a GS... They made spyders GS-T's.. And girls do dig the spyders
Old 12-04-2005, 11:59 AM
spydercrawler's Avatar
Sorry guys its a GS, its the woman's car so it fits her nicely, but I have to jump in and make it go, its time I did something with it as well. So to answer the first questions, its a GS
Old 12-04-2005, 12:54 PM
eclipsed4u's Avatar
read the sticky at the top of the forum for building a 420a track terror. that will give you all your answers.
Old 12-04-2005, 10:53 PM
slow420a's Avatar
ORIGINAL: eclipsed4u
wrong that car has a 4g64 in it 2.4 mitsu motor, not a 420a chrysler motor.
Your motor can hold 15psi intercooled safeley. What your going to have to do though is make your own turbo kit from scratch.
If it were my car this is what i would get
1g manifold, s16g turbo, custom dp, cat bypass, 3inch exaust, oil lines feed and return, fmic w/ custom ic pipes, bov, sfmu, plugs, plug wires. That sould get you going but your going to need a tune, either dyno or street toold to do that would be a fuel press gauge, wideband, egt gauge.
WIth all of that I can see maybe a mid 13 to low 14 1/4 mile run.
Old 12-05-2005, 10:05 AM
just as a question he can got to a junk yard pull head whole turbo system off of a gsx/gs-t get the head done put it on the 4g64 (i beleve it will fit but may be wrong) and bam instant turbo. the only thing im not sure about is the fitting of the head hey slow420a wont the 4g63 head fit on the 4g64.
Old 12-05-2005, 10:58 AM
eclipsed4u's Avatar
ORIGINAL: slow420a
yeah...my bad....i forgot it said spyder in the title
Old 12-05-2005, 11:41 AM
slow420a's Avatar
ORIGINAL: get435
Its an awseom idea and easier than trying to locate a tibburon block seeing how lots of older cars used the 4g63 and lots of newer mitsu cars use the 4g64. But its a little more involved then just bolting it on
http://www.dsm tuners.com/forums/showthread.php?t=152696
This is a post at dsm tuners (remove space) it goes a bit into detail about what needs to be done to makethe swap work... pretty much pluging oil spouts and getting some odd parts from other cars but its possible. Also if you hit google some kid made an actual site dedicated to the swap, he has a tsi awd and threw the 4g64 block in.
For the turbo setup... ya he can but the 4g64 is a larger motor then the 4g63... its like an inch taller or something. The problem you going to run into the down pipe off the 4g63 wont work on the 4g64. So that needs to be mede specifically for the car. Also he is going to need a fuel system, pump, injectors, sfmu or fmu. Now you could probally get away with taking a fuel rail+ injectors from a 4g63 and throwing them on the manifold... proly the same size injector boss but i am not too sure. Personally I would leave the head alone untill he wants to do a rebuild. ITs looking like he wants a weekend fun car.... seeing how its a sypder which is heavy as hell and has a wide body kit n all. If he was looking for serious speed he picked a bad platform and has 100 extra pounds of glass and mud on the out side of the car. I think if he does do the setup and only runs 10psi he will be happy with that.
Old 12-05-2005, 12:28 PM
tidus10's Avatar
motor swap to a 4G63 motor? thats what i want to do with my (96)eclipse spyder GS then just do all the mods everyone elts is doing :-P
yeah sorry i meant 4G63...
Old 12-05-2005, 04:48 PM
spyders have a 4g64 in them not the 420a. except the gs-t they ahve a 4g63.
civic4now
05-04-2007 11:24 AM
civic4now
05-03-2007 02:17 PM
civic4now
05-03-2007 02:05 PM
r1rx7girl
04-01-2006 07:00 PM
Quick Reply: 97 Spyder, needs tons of HP!, Help with suggestions
