98 Eclipse Taillights
Real easy. the only thing you are going to need is a 10 mm socket. just remove the panels for the side lights and you will se the nuts, unplig the bulb wires and pull them right of. now the middle is a little harder to do this you must remove the entire back panel. just use a flathead and pop up the panel the more nuts and you are done
