98 GS Trans Fluid Leak
its leaking from the passenger side drive axel.. weve replaced the seal twice and it still leaks.. could it be a bearing the the transmission? or something worse?
RE: 98 GS Trans Fluid Leak
soo.. nothing?
By any chance did you damage the case when you removed the axle seal? Is the axle installed in the trans properly?
woops haha wow i feel dumb
problem solved . thanks anyways though =] |
So what was the problem.
turns outit wasnt even a trans fluid leak, its an oil leak somewhere above the drive axel and its leaking onto the axel, spinning and slinging oil everywhere inside the compartment. haha but i feel real dumb now =/ replaced the axel seal twice and everything.. hahah
but so far we havnt been able to find the leak.. |
Welcome to the 420A. Leaks like a bitch. ;)
