99 eclipse cigarette lighter not working
checked my fuses they are all good took the cigarette lighter apart and saw 3 wires.. a black a black/yellow/ and a blue.. black/yellow and blue went to the light so i hooked up the black to the black on the cigarette lighter itself... when i took it apart no wires were connected .. and still no power.. tryed buying a new 12v one from autozone and that didnt work either.. any suggestions?
That's just weird it was not even hooked up. Perhaps it overloaded and burnt out some wiring and was intentionally disconnected. The cig lighter is a very high current circuit although these days it's used more for lower current items things like cell phone chargers, gps units, etc that don't draw near as much as the old push in lighter. I'd suggest at least investing in a cheap voltmeter if you don't have one for measuring. The center should be positive and the outside negative. You should see the cars battery voltage on the wires. If not start tracing backwards.
Originally Posted by BrokeDad
(Post 245807)
Did you ever check the fuse?
now does anybody know exactly what wires go to it? i can only see 3 wires and 2 of them turn the light on when connected so that only leaves me with one black wire left over which must be the power for the cig lighter?
Here is an online link to the 97-99 Eclipse Electrical Manual:
http://www.scribd.com/doc/6721606/97...ctrical-manual That should answer all your wiring questions. |
alright so i have found out the blue wire is the hot wire... the green/white and black/ yellow is for the light.. and the black wire must be the ground.. so i hooked up the blue wire to the cigarette lighter and i still have no power to it.. ive checked the fuse and thats good.. i cant figure out what im doing wrong..
I would check for voltage with a meter on those wires and make sure they are getting power before hooking up. It could be either shorting out or the wire is bad.
well ive checked the wires and only the blue wire is hot.. im really lost on this so how difficult would it be to run a new wire for the cig lighter? can i run a wire to the fuse in the fuse box? id love to get it working the way it is right now but im out of ideas
