Old Oct 4, 2006 | 05:11 PM
RCJr9186's Avatar
Default RE: ???
i'm not completely sure about the turbo'd cars but i know the best way to get more power out of a fully N/A motor is to raise the compression... also called Stroking the motor, basically upping the number on the compression of the piston... example the 420a N/A eclipse motor has an 8.8/1 Compresion ratio... by getting the 10.5/1 pistons or 12.5/1 pistons from a company such as Howell Automotive you raise the pressure in the compression chamber = more power. a really good example is the Acura RSX. the standars RSX has a 8.5/1 compression ratio at 160hp, the RSX typeS has an 11/1 compression ratio at 220hp... that's the best example i can think of. and by the way "???" is not a topic. please post your topic under the topic title
Old Oct 4, 2006 | 05:34 PM
Default RE: ???
i was gonna say something about the topic title too, but i figured just leave it alone for now.
Old Oct 4, 2006 | 09:55 PM
agallardo's Avatar
Default RE: ???
sorry guys about the title.
Old Oct 7, 2006 | 12:59 AM
agallardo's Avatar
Default RE: ???
Can I get a compression tester anywhere, or do I have to go somewhere "special?" How much for a compression tester? How much is an average engine rebuild?
Old Oct 7, 2006 | 01:04 AM
Default RE: ???
compression tester maybe $50 at any auto parts store. Rebuild kit maybe $300. But bad compression doesnt necesarily mean you need a rebuild, it could be bad valves, seals, or head gasket. It depends on how many are bad and which cylinders are bad
Old Oct 7, 2006 | 08:19 AM
Default RE: ???
Do the compression test and tell us the results!
Old Oct 7, 2006 | 10:31 AM
agallardo's Avatar
Default RE: ???
Will do guys. As soon as I get that money... LOL.
Anyway, its only $300 to rebuild my engine? Thats it? By the way, what exactly is included the the rebuild?
Old Oct 7, 2006 | 01:48 PM
Default RE: ???
No its 300 for the kit.. .the labour charge is what makes it BIG $$$
Old Oct 7, 2006 | 02:09 PM
Default RE: ???
mostly just gaskets
Old Oct 8, 2006 | 01:42 AM
agallardo's Avatar
Default RE: ???
Thanks guys for the help.
