-   -   Alarm Problem (https://mitsubishiforum.com/forum/2nd-generation-63/alarm-problem-1599/)
spierce Jul 2, 2004 11:28 AM
Alarm Problem
Hey all,
I have a Mitsubishi Eclipse 2000 GT and I am having a problem with the factory default alarm. All of the sudden, when the alarm is set or I test it by hitting the panic button on the remote, the horn no longer works. I checked to see if I somehow disabled the horn by running through the remote sequence that activates/deactiviates the "chirp" but no luck. I know that this sequence is working because there is a quiet double beep or single beep sound when I do this inside the car. The headlights blink on and off when I press the panic button or test the alarm but no horn! The horn works when pressed on the stering wheel.
I looked at the fuses and relays and pulled a couple of them and they looked ok.
A couple of questions:
1. Is there a seperate horn for the alarm than the stering wheel horn?
2. Has anyone seen this? Is there a reset or something that can get it back to normal?
Thanks,
Sonny
wildwest Jul 2, 2004 11:40 AM
RE: Alarm Problem
I dont know about the new eclipses. But generally the car horn is not the alarm horn. The alarm is a speaker. Bell shaped, kinda looks like a mini megaphone. usually low, to the side and forward of the engine. the car horn is a flat, casette size black box usually in front of the radiator.
spierce Jul 6, 2004 09:38 PM
RE: Alarm Problem
Thanks for the response. I did some more checking. There are two different horns, one for the alarm that looks like a disk and one for the stering wheel horn. I tinkered around a little with the wire that leads to the alarm horn and found that it has a break or is not connecting well. If I hold it in the right place it works fine. Now I know what I need to do to fix it.
Thanks again,
Sonny
wildwest Jul 7, 2004 12:09 PM
RE: Alarm Problem
your welcome... anytime... And feel free to post back. Dont just ask and run...
