Anyone have any idea
I hooked my obd - 2 reader to my car earlyer cus my light was on and i got a reading that my ignition coil a primary / secondary circuit malfuntion and i have no clue what that means.
RE: Anyone have any idea
and can anyone tell me if my 96 gs eclipse will most likely crankwalk or if it will happen or its just a matter of time. After reading a few articals on it makes me kinda fearful.
Could you give the exact trouble code- not just the code description? FYI- The crankwalk issue affects only the 2.0L Turbo engines with manual transmissions.
Joel, CA |
That code most likley means that your igniton coil is bad. Like stated above you car wont crank walk.
thanks for that info i was worried because when i make a hard left turn sometimes my car trys to die but instantly rebounds and i do have a slight ticking noise that i just related to normal motor noise.
As far as the actual code i dont know for sure because i erased it and when i went to re retrive it it didnt come back up. |
