auto engine and stick shift swap?
can i swap my auto engine with a stick shift engine on my 96 eclipse rs? what kinda would fit?
RE: auto engine and stick shift swap?
You change the transmition not the engine. And there is a bit of work because you have to put in the clutch pedal, master cylinder, and the shifter.
ORIGINAL: customizedrides You change the transmition not the engine. And there is a bit of work because you have to put in the clutch pedal, master cylinder, and the shifter. |
how much would it be for installing everything you just said if i already had the parts? also, how much is if i wanna swap engine from 2g to 1g(installation fee only)?
| All times are GMT -5. The time now is 10:31 AM. |
