-   -   Balance shaft? (https://mitsubishiforum.com/forum/2nd-generation-63/balance-shaft-37715/)
DaSiver Nov 26, 2010 03:18 PM
Balance shaft?
Have a 97 Eclipse GSX. Doing a head gasket replacement. The Haynes book I have refers to aligning the balance shaft on the Turbo engine. Problem is, I don't have a balance shaft. The crank pulley has the balance shaft sprocket behind the timing sprocket. Any design change for this particular engine in 97?
KaiserEclipse Nov 26, 2010 09:21 PM
other than a different thrust bearing design for the 7 bolt block i cant think of any difference in that engine
DaSiver Nov 27, 2010 12:08 PM
Thanks. I think I've figured it out. After doing some research I found out that they sell balance shaft elimination kits. I never would have guessed.
