bent bearing
how long it will my car last until my engine seizes up?
RE: bent bearing
DONT RUN IT!!!! if you spun a bearing and you run the motor after not very long it will be completely unsalvagable. At least after it happens the metal particals havent run threw the head and turbo (if your turbo motor) yet so those parts can be reused but if you run it for to long at some point the head turbo cams ect ect will get so scored up they will be easier to replace then rebuilt
RE: bent bearing
okay i may have the spun bearing problem myself but i have not run it AT ALL.
How incrdibly exstensive will it be to redo the bearings |
RE: bent bearing
might as well consider it done for already
what beareing are you talking about exactly? you never specified |
RE: bent bearing
well im guessing hes talking about the rod bearings
RE: bent bearing
yea its my rod bearing...would it be easier to just replace or buy another engine
RE: bent bearing
It all depends on how much damage it has done to therest... the only way to tell is pull it all out and see.
