Big 16g
Old Apr 30, 2008 | 08:23 PM
19gst98's Avatar
Default Big 16g
so where is a good place to buy a 16g turbo kit? lol
Old Apr 30, 2008 | 08:38 PM
Old May 1, 2008 | 12:23 AM
dorian7's Avatar
Default RE: Big 16g
www.dsmparts.com is another good one. Don't forget you need the install kit too.
Old May 1, 2008 | 12:45 AM
tjbiker031's Avatar
Default RE: Big 16g
and stay away from ebay, i heard stories where the turbo dies after one pull
Old May 3, 2008 | 01:10 AM
19gst98's Avatar
Default RE: Big 16g
any other suggestions? lol
Old May 3, 2008 | 04:09 AM
silvercoupe97's Avatar
Default RE: Big 16g
I would suggest skipping the big16G and going with the Evo316G from one of the sites suggested above or my favorite... Forced Performance
The compressor wheel on the E316G is slightly larger than the B16G and both are usually the same price.
As suggested, don't forget to either put a kit together yourself or buy a 2G kit. A suggestion to you, get the larger 34mm wastegate flapper or you will boost creep if the turbo is set lower than 18psi.
Old May 3, 2008 | 08:58 AM
TheAdvocate's Avatar
Default RE: Big 16g
www.extremepsi.com
Old May 3, 2008 | 11:18 AM
sk8dudety's Avatar
Default RE: Big 16g
i have a question, something that might clarify something for him and me haha... is there a difference between a e316g and a big e316g? cause i'm pretty sure i've heard of teh big e316g and wasnt sure if it was just an added word they tagged onto it
Old May 3, 2008 | 11:30 AM
Default RE: Big 16g
I dunno about that. But there is a difference in the BIg 16g turbo and a normal 16g turbo. Im not sure of the actual codes on them..
Old May 3, 2008 | 06:04 PM
Default RE: Big 16g
ORIGINAL: sk8dudety
Forced Performance suggests that the E16G has a slightly larger compressor wheel over the B16G.
I don't recall ever hearing about a "big" e316g though. It sounds to me like someone was trying to make the e316g bigger than it really is or was suggesting that it is "bigger" than the b16g and tagged it with "big". My suggestion is to research the facts and go from there. The sleeper 16g is the only 16g variant that is e316g worthyand that thing is more than double the price of the other two 16g variants. Check FP's site, they tell the tale of the four 16g variants.
