big big problem
well here it is maybe two weeks ago i had my car on the dyno and was ready to tune it when the guy saw my timing belt and saw it being eaten up on one side of the belt,i change the belt and water pump right after and the pulleys and tensioners loooked just fine,now the the new belt is begining to do it again.what could it be touching?could it be the timing belt covers? or something else let me know
RE: big big problem
Nobody can tell you....... thats something you gotta look for yourself.
Pull the cover off (its not hard) and take a peek. Sometimes there is **** at the bottom of it.... |
RE: big big problem
one of ou pullies could be f-ed up and making it twist weird or something?
RE: big big problem
nope the belt spins just fine,i guess its probally just some thing stuck in there
RE: big big problem
Yeah.. probablya piece of crap on the cover
RE: big big problem
well i figured out what it was,it was the front strut tower bar,everytime the motor kicked ,it would hit the bar,anyone ecer heard of this hapening(i dont have my timing belt cover on)(upper)
RE: big big problem
ORIGINAL: Gstfat well i figured out what it was,it was the front strut tower bar,everytime the motor kicked ,it would hit the bar,anyone ecer heard of this hapening(i dont have my timing belt cover on)(upper) |
RE: big big problem
yeah, the two bottom (front and back) break alot and will give you lots a play. i would think about getting poly inserts for those two...even if they arnt broken, they may be worn out.
RE: big big problem
you can also get an engine damper,
it bolts up by the top of the strut on the cam gear side, it will keep the engine from rocking as far. but it does sound like you need some mounts. i had one broken one and my engine rocked back and forth severely. |
RE: big big problem
My suggestion would be first and foremost, buy a cover! Next, buy new mounts, inserts, or get some used mounts and make your own stiffer mounts from a set of old mounts and liquid nails or the likes.
My other suggestion is to remove the strut bar. It does nothing but allow the two towers to move at the same time, same distance in relation to the other, and in the same direction. Unless the bar is connected to the firewall, it's useless since the towers already do this with minimum variation. Why do you think EVOs use a three contact strut brace and not a bar. ;) Take that bling off and use it for something else like a hatch prop or hood prop or even an onboard anti-theft device. |
| All times are GMT -5. The time now is 05:46 AM. |
