-   -   boost gauge, firewall (https://mitsubishiforum.com/forum/2nd-generation-63/boost-gauge-firewall-3959/)
1998blackgst 240 Apr 11, 2005 07:08 PM
Where should i run the boost gauge hose through the firewall? on a website it says through the throttle cable hole, but thats closed up., should i unbolt the cover to the hole or what hole should i go through
Sanguinius Apr 11, 2005 10:31 PM
RE: boost gauge, firewall
I'd say go through wherever it's going to look good. Whether you have to drill yourself a new hole or go ahead and open hat cover go for a good look and proper installation. Taking th easy way out will only cause you problems later I garauntee it.
DSMTalonAWD51 Apr 12, 2005 12:49 PM
i ran my hose through the firewall where the steering column goes through the rubber boot. just tuck it behind the carpet so it doesnt get in the way of anything. it will also come out exactly where you want it to, you're going to want to connect it as close to the intake minifold as you can get.
mitsunoobie Apr 12, 2005 03:58 PM
yeah i ran mine through the rubber boot thing in the collum as well and hid it behind the dash all the way to my g pod so i would go through tere
1998blackgst 240 Apr 12, 2005 05:49 PM
I did it through the steering column boot, thanks alot , looks really good
