Cam and Crank Sensor Question
What would cause these to repeatadly fail?? Ive replaced the Crank one 3 times and on my second Cam one now. runs for like 30 minutes, then sensor is bad again. Any help?? thanks in advance!!!
RE: Cam and Crank Sensor Question
I would test the voltage in the lines. Maybe there is some abnormalities there. Check the grounds too....
Make sure the area has NO water or grease or anything... and that its tight |
