-   -   Car/Shifter wont move? (https://mitsubishiforum.com/forum/2nd-generation-63/car-shifter-wont-move-23428/)
USER_22 Nov 12, 2007 07:27 PM
Ok I can shift the stick around into any gearjust fine with the car off, butassoon as I turn the car on it refuses to shift into any gears, anyone know whats wrong?
itsme71190 Nov 12, 2007 07:29 PM
RE: Car wont move?
wat kind of car?
USER_22 Nov 12, 2007 07:31 PM
RE: Car wont move?
99 eclipse rs
estraw Nov 12, 2007 08:10 PM
RE: Car wont move?
slave and/or master cylinder is probably your culprit
USER_22 Nov 12, 2007 08:17 PM
RE: Car wont move?
What, can you please put that is noob terms lol. I mean the car was work just fine yesterday, I came home and parked it and now it wont move.
nick_200321 Nov 12, 2007 09:31 PM
RE: Car wont move?
try this... put it in gear, push the clutch and try to start it... make sure the E-Brake is on!! if it tries to jolt forward then stalls you might just need to adjust the clutch, or as estraw said, your slave cylinder( a black piece on bottom front of tranny that has a rod going into it) might be going out.. i recomend adjusting the clutch if it happens though... might help
USER_22 Nov 12, 2007 09:52 PM
RE: Car wont move?
I held down the clutch and started it but after thatit just sits in N. When I try to move the shifter to any gear it feels like something is moving in the way or something. Its like a wall in jumping out in front everytime I try to put it in a gear. Kinda weird when it was working fine yesterday.
nick_200321 Nov 12, 2007 10:17 PM
RE: Car wont move?
well if it was working fine yesterday it is prob. the slave or master cylinder... im leaning on slave cylinder side... look it up and you will see a pic of it, they are like 20bux at advance auto
USER_22 Nov 12, 2007 10:21 PM
RE: Car wont move?
K, kool ill check it out tomorrow and see whats going on. thx.
TheEngineer Nov 13, 2007 06:42 AM
RE: Car wont move?
Are you starting it in first or in nuetral. Cuz you want to try first and as soon as the car starts it will most likely stall on you
